Farmall Tractors Discussion Board
Re: Re: Re: Re: Ok...got the brake cover off and here is what I found -
Posted by Farmall Newbie on November 17, 1999 at 20:19:35 from (207.89.136.115):
In Reply to: Re: Re: Re: Ok...got the brake cover off and here is what I found - posted by Farmer Bob on November 17, 1999 at 20:07:10:
Well Bob, when your at the mercy of someone more knowledgeable than that of myself when it comes to these things you learn to be quick :PP
Ok...that "Drum" on the tractor looks like it is held on by a single nut..is that right? And I suppose Ill need a gear puller to get it off ( hopes not ) Are you telling me that I should order 2 seals per side? Or 2 seals and replace each side?
Thanks Bob -
Post a Followup
: Re: Re: Re: Re: Re: Ok...got the brake cover off and here is what I found -
