Re: Super A Hybrid???
Posted by Mr. Dan on November 23, 2004 at 14:06:22 from (216.12.192.74):
In Reply to: Re: Super A Hybrid??? posted by SAm in NS on November 22, 2004 at 17:37:35:
Folks, thanks for the help.
Regarding the carburetor: I already had the small circular disc on the top surface as clean as a pin... just didn't know what I was seeing. It shows model no. 12613A with the accompanying no. of 375560R91 (see post from "Kevin in Va." on 08-16-2004 04:04:53).
The "Tractor Carburetors - OEM Cross Reference Guide" lists this carburetor as
OEM # -- Carb# - Manu. - Applic. --- Engine
12613A - 161X7 -- IH -- C113,C123 - A;B;C;SUPER C
[note: it doesn't mention Super A!! and it doesn't show a rebuild kit].
Fortunately I DO have a Case-IH dealer about 8 miles away and I've seen his computer searching for a sediment bowl. I'm much closer to a solution on this problem.
Regarding serial/casting numbers: The 354898 # (including the R1 suffix) IS behind the oil filter... and finally (with the aid of a 1 mil candlepower light) I found the stamped-in serial number plate:
| FCM G|
| 155540 |
That's right -- ONE-5-5... [It is smaller than I imagined after seeing the casting numbers and is behind the coil and exactly hidden by the throttle rod.]
The casting number 351687R1 is cast upside down on the very back of the clutch housing. The date *9-22-47* (all *'s look like slotted screw heads) is cast in the transmission below the shift lever.
The block date of *6-20-X* is still a puzzle. The right screw head image appears to be jammed up against the intersection of the X.
Any further help with these numbers?
Thx, Dan
Post a Followup
Subject:
