Re: B-414 engine and electric?
Posted by Jokke on November 25, 2004 at 08:10:41 from (213.224.82.78):
In Reply to: Re: B-414 engine and electric? posted by Michael Soldan on November 25, 2004 at 07:01:39:
Well, I did think that the cap on top of the valve cover is the oil fill, but what kind of cap goes on that tube, now there's just the "blow-by hose" wich I don't think is near any original part. And I don't think these tractors had blow-by tubes, at least our B-614 and 634 don't have that tube.
But they have a "venting cap" on top of the valve cover and an oilfill tube at the right side of the engine. the 414 has a diesel engine. Maybe the gas engine is a little different.
Well and for the wiring diagram, I don't really need it. I just need to know what switches are supposed to be in the dash. Wiring it correctly is that much of a problem if you can start from scratch.
I know that there's supposed to be a lightswitch (that one is still in the dash), But then they've put so many other switches on and under the dash,I just can't find out what's needed.
there's one pre-heat switch(key operated), an ignition switch (also key operated), the old lightswitch, a new pull-type lightswitch and a switch for the turn signals, and 2 pushswitches(don't know what they're for, are wired but nothing happens)
What did these old 414's have?
lightswitch
ignition/pre-heat switch (or are these separate)
startswitch is on the starter, it has the original "Lucas" starter
If someone can tell me what switches are needed, and how they look like, that would be great.
Maybe someone can take a picture from the dash and/or valve cover with the cap on top
Thanks
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
