Re: B-414 engine and electric?
Posted by Okie Dave on November 29, 2004 at 10:19:23 from (152.163.101.13):
In Reply to: Re: B-414 engine and electric? posted by Jokke on November 25, 2004 at 08:10:41:
I have a 364 which is a newer version of the 414, and also has the BD-154 engine the cap on mine dosn't have the hose you are talking about maybe it's a add on, although mine has a vented cap on the filler which is a crankcase vent. As far as the wiring you need to get a manual, lots of tractors are wired different. Hope this helps.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
