Farmall Tractors Discussion Board
Re: Re: Re: Super A Charging System
Posted by Curt Cooke on November 21, 1999 at 17:02:38 from (207.75.224.113):
In Reply to: Re: Re: Super A Charging System posted by Stan on November 21, 1999 at 15:29:18:
Stan, here's what you did. You provided full current to the electromagnets in the "field" of the generator causing the generator to max charge. The contacts I told you to manually close, closed automatically due to the charge provided to the solonoid that pulls these contacts together. The main thing is that the contacts separated when you shut the tractor off, indicating that when the voltage dropped, the contacts opened as they should. You "woke-up" that solonoid is what you did. Now, you can adjust the "field" solonoid inside that regulator so as to provide more charge so it can keep things going when the lights are on. Play with this notion with the engine running and someone watching the gauge.
Curt
Post a Followup
: Re: Re: Re: Re: Super A Charging System
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
