Farmall Tractors Discussion Board
Re: Re: Super A Charging System
Posted by Stan on November 21, 1999 at 15:29:18 from (12.76.70.136):
In Reply to: Re: Super A Charging System posted by Curt Cooke on November 20, 1999 at 15:48:00:
To all who offered suggestions, thank you very much. I am once again very impressed with the help you can get on these boards.
Her's what I did. Now please tell me what I did. I connected a jumper wire to the J post on the generator and touched it to the positive terminal on the battery and the charge meter jumped toward the plus side. I thought this would stop when I disconnected the wire but it didn't. I let her run for 20 minutes than shut her off and started and it turned over like it used to. Still when I turn the lights on the needle shows a negative discharge. I think mabey the battery was so low it may need more charging.
Did I just Re-polorize the regulator or is there something else ??
Post a Followup
: Re: Re: Re: Super A Charging System
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
