Farmall 706 Carb. advice
Posted by kpowl on December 08, 2004 at 04:10:50 from (170.54.59.167):
I have a late model Farmall 706 with the 291 gas engine in it. The tractor was fine until I recently filled the tank up with fuel and then it started running rough especially at idle speed. I thought maybe I got some skunked gas so I completely drained the tank. I looked inside the tank and it was clean with no rust or debris. I took the carb off and took it to a local professional carb rebuilder and he went through it. He said it was a little dirty but not bad. I put the carb back on the tractor and put some premium gas in the tractor and it runs a little better but not perfect. I was curious if the electronic solenoid on the carb would be causing any of the problem or ? I am open to any advice.
Thanks
Post a Followup
Subject:
