Re: Farmall A cooling system
Posted by Red Dave on December 14, 2004 at 17:20:03 from (209.86.77.230):
In Reply to: Farmall A cooling system posted by Dente on December 14, 2004 at 16:28:38:
Your A has a "Thermosyphon" cooling system. It works by the convection currents of heated water. hot water leaves the engine out the top to the radiator, then cools in the radiator to sink and displace the water in the bottom of the engine and start over again.
For it to work, the radiator water level has to be up almost to the neck. Also don't forget to make sure your fan belt isn't slipping.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
