Farmall A cooling system
Posted by Dente on December 14, 2004 at 16:28:38 from (152.163.101.13):
Just replaced the fan assembly on the A. Warmed her up and now it seems to me she is running hot. I had to pull the radiator and take off the top inlet port on engine to get the stripped bolt off of tge fan . Looked in manual. Seems their is no water pump and they call the cooling "thermospin". Should I not worry about the cooling system or is their something I should be aware of? Wondering why their is no temp. guage on the two A's I have. My M.D has the guage.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
