Hydraulic Plumbing
Posted by PAULIH300 on January 30, 2005 at 13:41:05 from (205.188.117.13):
My 300U with U-34 loader has a screwed up plumbing situation with the lift,dump valves.The lift lever is on the outside and lifts when pulled back.The dump valve is on the inside and dumps when backward and raises when forward.These are reversed from what I read.The lift is supposed to be inside and the dump is outside,with the forward dump position to dump and rearward to raise.The lift should lift forward and drop rearward.Here's the funny part.....the other port on the lift valve has a hose crossing over to the other side of the reservoir and plumbs into the bottom of the reservoir.They have the valve set to Dual Action even though the lift cylinders are Single Action.The engine labors when you drop the bucket (should be freewheeling).What did these former knuckleheads do?? (setting the valve to Single Action wont lift the bucket/arms).
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
