How many spacers on starter armiture (Farmall 560)
Posted by Old_Farmall_560 on March 07, 2005 at 06:43:08 from (216.167.150.4):
Can anyone tell me how many spacers (washers) should be on the starter drive end of the starter armiture shaft of a Farmall 560 LP? After having my starter rebuilt and a new armiture installed, I find the mechanic reinstalled only one spacer back onto the engine-end of starter armiture shaft. This is the small washer with the wire clamping spring. Is this all the spacers normally used? The rebuilt starter worked fine right after it was installed but is now giving me problems after the tractor sat for several weeks while the head was reworked.
The problem as I had posted before is that my starter continues to spin the engine after the starting sequence is initiated even after the dashboard push button is released. I have to pull a battery cable to stop the starter. I've now replaced the solenoid, replaced, cleaned and tightened all grounds, checked the wiring hookups, eliminated the push button switch from the circuit, cleaned and oiled the starter drive, and shimmed the starter with washers. Nothing has worked. Has anyone had this problem before on a Farmall starter and what did you do to solve it? Help!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Tractor Profile: Ferguson TO-20 - by Staff. When the infamous "Handshake Agreement" between Henry Ford and Harry Ferguson fell by the wayside (that's a story in itself), Harry Ferguson quickly set up manufacturing plants for a United States version of his English TE-20. The TO-20 was relatively the same as the TE-20 except utilized some different casting materials and had a US-style electrical system. The TO-20 was a dead ringer for the Ford 9N and 2N models and they say that Ferguson did this on purpose when the Handshake Agreement wen ... [Read Article]
