Re: Farmall C Pistons Stuck Rods Stuck, too
Posted by El Toro on April 30, 2005 at 03:53:13 from (205.188.117.138):
In Reply to: Farmall C Pistons Stuck Rods Stuck, too posted by PurdueAg on April 29, 2005 at 20:27:53:
You need to pour some transmission fluid into each cylinder and let it soak. You do not want to
hammer around the crankshaft with anything that's metal. Use a piece of oak that's long enough and
tap on that, but don't hit so hard you may damage the block. I don't think those pistons or sleeves
should be used. It's a lot easier to work on if you pull the engine. Then you may be able to remove the crankshaft so you some clearance to work on the pistons. A lot of times the sleeve will come out with piston and then I used a torch to heat the sleeve. You need to patient too.
Hal
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
