Re: cuts out....gas?
Posted by Nat on May 28, 2005 at 11:18:23 from (24.93.8.168):
In Reply to: Re: cuts out....gas? posted by ToddH on May 28, 2005 at 10:59:49:
It's a fuel flow issue inside the carburetor.
A bad coil will overheat and stop working, but once you let it cool down, it'll work again for a while.
Post a Followup
