Re: cuts out....gas?
Posted by ToddH on May 28, 2005 at 10:59:49 from (64.78.123.117):
In Reply to: Re: cuts out....gas? posted by El Toro on May 28, 2005 at 10:23:47:
The flow is good going into the carb. When it starts to cut out, I sprayed starting fluid into the intake and it kept running. Doesn't that mean that it is a fuel problem (in carb)? I will be glad to replace the condensor and coil if needed. If they are bad, why would it run good for a short period after sitting? I don't doubt you, I am just trying to get educated. Thanks so much. Todd (and wife who can't wait to see 18" tall grass get cut :-(
Post a Followup
