Re: super m carb serial number
Posted by ChadS on June 12, 2005 at 11:05:37 from (66.228.96.231):
In Reply to: super m carb serial number posted by farmall on June 12, 2005 at 09:33:26:
All of the throttle bodys from the M-MTA were the same, they did have different part numbers, but were basicly the same casting. The 400-450 carbs have the idle screw in the carb flange, where the M-MTA has the idle screw along the lower side of the venturi. The carb bowls are different on the SM and MTA, the choke is on the opposite side of the bowl, M's have them on the left side, Supers had them on the right. (towards the engine) Most differences were main jet size, venturi size, and the choke shaft was a different diameter. Keep you throttle body, and the venturi from the origianl carb off the MTA, just use the carb bowl from the carb you found. That keeps the origianl part number of the throttle body on the MTA. Now as far as jet drilling,,,, If that MTA is a stocker,, you dont have to drill it much,,, maybe 2-3 sizes larger than the original jet size. if you went more than that, you went too far. You also have to remove the brass metering stem when you do this, otherwise you will drill right through the stem, and it will run erratic. Too rich. If the stem is ok, you can still use the bowl you drilled out,,, you just wont have any kind of fine tuning adjustment, 1/8 to a 1/4 of a turn, and its either rich, or lean, like on the usual,, you have to back it out a couple of turns to see a change in the engine's fuel mixture. It will be extremly tempermental on where the main load adjustment is set, cause you may have lost the fine tuning ability by going too big. If you do choose to attempt this again, it wont take much, maybe 2 drill bit sizes from the origianl jet,,,, if you can back the adjustment out all the way, while its under a load, and it does not run rich, then a jet change is nessisary, if it does run richer, and you can notice a change, then the jet size is fine where its at. Hope this helps,,, ChadS
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
