Re: Farmall M Clutch Pressure Plate
Posted by JohnG(TX) on June 28, 2005 at 06:20:05 from (216.136.20.34):
In Reply to: Re: Farmall M Clutch Pressure Plate posted by Haas on June 27, 2005 at 18:41:03:
My actual problem is in getting to the top bolts on the pressure plate. The engine won't turn, so I can not rotate the flywheel to get the bolts to the lower part. Is there enough room to get a socket or wrench up into the top portion of the bell housing? If not, and I just can not get the shaft out, then I may have to cut it.
Post a Followup
