Re: Cub keeps cutting off! Help!
Posted by El Toro on August 01, 2005 at 18:53:56 from (64.12.117.13):
In Reply to: Cub keeps cutting off! Help! posted by GNB on August 01, 2005 at 18:31:57:
You need to check for a hot spark at the sparkplug when the tractor dies. Have someone to
try and start the engine while you hold the plug wire away from the plug. Should be a hot spark.
If this tractor has been converted to 12 volts
and has a ballast resistor it may be shot.
Try a new condenser, but it could be a weak coil.
Hal
Post a Followup
