Re: electrical charging question on '41 H
Posted by John T on September 18, 2005 at 07:43:58 from (66.244.90.98):
In Reply to: electrical charging question on '41 H posted by awutay on September 17, 2005 at 15:34:40:
Awutay, let me know if you have a 2 wire cutout relay system or a full fledged 3 wire Voltage Regulator and I will post a Troubleshooting Procedure for non charging. Regardless what came original, many got converted so I cant say fer sure what you now have.
A Cutout Relay is a smaller 2 wire device usually Generator mounted that has a BAT terminal wired to the ammeter and the GEN (or ARM) terminal wired to the Gens Armature post. On those systems the Gens Field post is wired to the switch.
A 3 wire Voltage Regulator has 3 terminals BAT ARM (or GEN) and FLD. BAT on VR wires to the ammeter,,,,,,,,,GEN (or ARM) on VR wires to Gens Armature post,,,,,,,,,,FLD on VR wires to Gens Field post.
I could post a long winded trouleshooting procedure for either (VR or cutout relay), but its easier and more understandable if you let me know which system you have.
John T Nordhoff in Indiana, retired electrical engineer
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
