Re: electrical charging question on '41 H
Posted by awutay on September 18, 2005 at 18:35:59 from (12.76.131.104):
In Reply to: Re: electrical charging question on '41 H posted by John T on September 18, 2005 at 07:43:58:
John,
I went out to look at the H. Here's what I found:
on top of the generator is the cutout relay or voltage regulator.
If you were sitting on the tractor you would see three electrical
spade lugs on this box. Two lugs are at the front horizontally
opposed to each other. The last lug is on the right side of the
box at its rear.
Two wires lead from the box. Both are attached to the front two
horizontally opposed lugs. The left side connection goes to the
ammeter/switch box on the steering column. The right side
goes to what appears to be the letter 'A' stamped on a terminal
on the generator.
The only other interesting piece of information is the unused
connecton at the rear of VR/cutout relay is stamped with the
letter 'F', although the connections that have wires coming from
them have no markings.
So, do I have the VR or cutout relay and what is the proper
troubleshooting procedure?
Thanks,
Art
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
