Re: Farmall A Heavy Wheel
Posted by El Toro on September 22, 2005 at 04:07:43 from (64.12.117.13):
In Reply to: Farmall A Heavy Wheel posted by RETCOL on September 22, 2005 at 02:51:43:
I would say the left side if used for plowing since more tractor weight would be on right side
when the right wheel is in the furrow. Hal
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
