Re: 49 Farmall H RefusesTo Start
Posted by El Toro on November 01, 2005 at 18:35:58 from (152.163.101.13):
In Reply to: 49 Farmall H RefusesTo Start posted by Flatland Farmall on November 01, 2005 at 17:43:56:
Are you getting voltage to your coil with switch on? No voltage there you need to check at your ignition switch for voltage in to and out of the switch. That switch is fed from the small hot terminal on your starter solenoid. Set you meter on dc volts and check each location for voltage. No voltage at switch check at the small solenoid terminal. Voltage here & none at switch your wire has a bad connection or is broken. You need to do the process of elemination. Are these new points? If not, points could be pitted or dirty. Gap & clean. Hal PS: One of those small solenoid terminals will not have voltage until you push the starter button to crank the engine and once you release that the engine stops cranking. So there has to be voltage at the starter since the engine will crank.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
