This question is electrical !
Posted by Randy-IA on November 12, 2005 at 21:17:21 from (207.177.83.185):
Hi , I found out my M originally had a unregulated 6 volt electrical system while reading the owner's manual . It has a four position switch which controlled the charging system and the light's ( Which are burned out it seem's , there's still juice to the housing's ) . Since it's been converted to 12 volt's with a alternator sometime long ago , do I need to use the switch as a regulator ? This afternoon while playing in the field with it I noticed that the amp gauge was pegged out on the charge side . That , I thought , was because I had used the starter so much when I had it flooded . But maybe not ? I didn't know what the L and the H on the switch were for until I read the electrical section in the manual a little while ago . I don't need to adjust the charge rate of the alternator do I ? It doesn't have a off position so do I still put it in the L position regardless ? It appears like the original wiring harness was used to the alternator with more modern wires used through the resistor to the coil . Any advice ? Thanks ...Randy
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
