Re: This question is electrical !
Posted by John T on November 12, 2005 at 21:42:37 from (66.244.90.98):
In Reply to: This question is electrical ! posted by Randy-IA on November 12, 2005 at 21:17:21:
Randy, Although I cant say for sure exactly not knowing how someone may have jury rigged your switch n system, if the Alternator is an internally regulated unit, such as a GM 10 SI, it doesnt require any external voltage regulation (it does require an excitation voltage circuit to its lil No 1 side terminal, see below) and WOULD NOT need to be wired to the combination light and field control charging system switch (L H B D) like they used for the old 2 wire cutout relay charging systems.
The resistors in that type of combo regulatign switch suppled EITHER a dead ground for the Gennys Field for High charge and a ground via a resistor on that switch for Low charge. It can still be used as a light switch if its good, but its not needed nor wired to an internally regulated alternator.
I have seen the GM 10 SI 3 wire alternators jury rigged up all sorts of ways to excite their fields/rotor so its no telling what you may have and how your switch and alternator is wired now. When I wire the GM 10 SI I use a 10 ohm current limiting protection resistor and a diode if needed in the excitation circuit, but I usually feed that off the Ignition switches IGN terminal or off the coils high input side. Most alternators are for Negative ground, in which case one has to rewire the coil and swap ammeter leads if it was an original Positive ground tractor.
YOUR SPECIFIC QUESTIONS:
Soooooooooo, NO you do NOT need to adjust the charge rate of an internal regulated alternator.......... It shouldnt matter if its in the L or H position, cuz theres no Generator wired to it, and therefore its resistor (Low charge) or its dead grounding (high charge) positions are of no consequence for your alternator, they were for a generator.
You mentioned a resistor and a coil?????? If its a resistor in series with your Ignition Coil, they may have used the old original 6 volt coil and needed a voltage dropping (12 to 6) Ballast Resistor in series. Its wired after the ignition switch and ahead of the coil if its an ignition ballast resistor.
When I rewire for an alternator that had a genny previously, I replace any 12 gauge wire in the charging circuit with 10 gauge.
Post back any question, good luck n God Bless
John T, retired electrical engineer
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
