H ignition
Posted by Joe Dowling on January 24, 2006 at 16:50:04 from (169.244.70.148):
Would it be a smart idea to replace the distributor on my 1952
"H" with an impulse magneto? I"d like to hear from some people
who have done it and what benefits there might be gained.
I"ve replaced the points, condenser, wires, cap rotor, and plugs
(basically everything) and I still have some misfire under a heavy
load in 4th and 5th gears. Any suggestions? The tractor is only
used a couple of dozen times a year.
