Re: How much paint
Posted by the tractor vet on March 14, 2006 at 17:11:23 from (64.179.117.193):
In Reply to: Re: How much paint posted by daniel Jessup on March 14, 2006 at 17:05:11:
I would like to know how you can get away with just a gal. and yes you can do the axels black the rest well that is your choise but not the way they came from the factory as for the manifold pain it all red and the heat will turn the red black in no time if worked. .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
