Re: B valve adjustment, what happened?
Posted by El Toro on April 13, 2006 at 13:23:22 from (205.188.116.133):
In Reply to: B valve adjustment, what happened? posted by TKN on April 13, 2006 at 11:48:20:
You used the correct procedure, but you need to set the valve lash at .017" cold. At .014" cold
they're probably at .011" when hot. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
