Re: B valve adjustment, what happened?
Posted by Charles McNelly III on April 14, 2006 at 17:19:32 from (65.54.98.27):
In Reply to: Re: B valve adjustment, what happened? posted by El Toro on April 13, 2006 at 13:23:22:
My IH Service book for my B says this; A clearance of .014 inch, measured when the valves are closed and the engine is WARM, is necessary between ends of valve levers and stems. If you set these up with the engine cold at .017, depending on the expansion of the metal in use, whos to say it would be right? Set them up like the manual says and there shouldn't be a problem. It also says to readjust them after 400 hours of operation.
