Differential Fluid in M
Posted by turbos10 on May 28, 2006 at 20:50:47 from (67.76.50.36):
Guys,
When I drained the diff. fluid in the M, it was kindof whiteish. It looks similiar to an oil and water situation, but I dont see how this could be the case unless some water could have leaked in the top cover. Just curious if any of you have seen diff. fluid that was this color, but I will say if was also thicker than I have seen.
To get to the point, is there some diff. oil that is this color or should I go ahead and get new?
