Re: removing fan on 400
Posted by CNKS on June 04, 2006 at 19:42:40 from (204.249.178.138):
In Reply to: removing fan on 400 posted by budaa on June 04, 2006 at 19:12:53:
You can probably get the broken part from salvage, not sure anyone makes those. The pin holding the water pump drive/springs on has a nut on the other end. Remove the nut and pull the pin and the drive comes off.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
