outer axle bearing in 300 farmall
Posted by MoMike on June 07, 2006 at 17:53:20 from (208.27.172.210):
Question, is it possible to replace this bearing without removing rear axle housing. Rear seals are leaking so i put tractor in shop and pulled rear wheel, cover found shot seal and worn bearing. IT manual says to remove axle housing to change bearing, with major undertaking to do so.
