allan ne, 666 hydro repair
Posted by maplehillfrm,pat on June 10, 2006 at 07:31:43 from (170.215.213.128):
hello allen, I am not sure if this is too far down the list to see, but I got the foot n inch valve closed, and changedthe 2 capsules, no difference in operation, I took the side panel off on the left side , it has 6 bolts holding it on, I can see where the S R goes from forward to reverse with it off, On the inside of there it appears to be a plate that moves when the SR is moved, is this like a clutch plate sort of, because i see there are two pistons that appear to be able to ride on there , maybe if there is pressure applied from the other side, are these supposed to be loose until pressure applies to the plate? what next?? pat
I reposted the question here from page 7, thanksfor any help.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
