Re: Delco Remy distributor on a 1942 H
Posted by RustyFarmall on June 29, 2006 at 06:13:05 from (216.248.75.138):
In Reply to: Delco Remy distributor on a 1942 H posted by Scott Rong on June 29, 2006 at 05:39:52:
Your H originally had a magneto. The magnetos were a bit troublesome so the vast majority of Hs had the magneto replaced with a battery ignition distributor. Some of these distributors were the upright Delco such as you have, and some of them were the IH built units. Neither of these is "correct", but both are appropriate. If you want your H to be "correct", you will need to change it back to a magneto. If you don't care, it don't matter. If it ain't broke, don't fix it.
