Re: 1971 IHC 454 Gas, 38 hp, loader, hydraulic que
Posted by FromJB2 on June 29, 2006 at 19:55:44 from (69.198.143.165):
In Reply to: 1971 IHC 454 Gas, 38 hp, loader, hydraulic questio posted by Terry Hensley on June 28, 2006 at 20:08:23:
Hi Terry, that silver colored mud is most likely chewed up parking brake band and will clog the filter again. Use only Hytran or equivilant hydraulic oil. The weak lifting can be:
1) clogged filter or lo hydraulic fluid level
2) stuck or bad pressure relief valve
3) MCV valve not working propperly
4) weak pump
Does power steering work OK?
Number 1) you can change filter and fluid a couple of times. The other causes require special tools to test pressure and flow rating of pump.
Good luck
JB2
