Re: Help with new Farmall H
Posted by williamf on July 14, 2006 at 16:59:19 from (69.19.14.24):
In Reply to: Help with new Farmall H posted by Lincoln on July 14, 2006 at 16:31:50:
It's not live hydraulics. The power from the pump (the brand name is "Liftall") comes back from the transmission; if the clutch pedal is depressed the pump's not pumping. Takes some getting used to.
All three outlets are supplied from the same source - the one lever works them all. The one on the right and the front one on the left move first and when the cylinders they're pushing reach their limit a (similar to a relief) valve opens to supply the rear outlet on the left.
Anything more complicated you have to add valves and plumbing. Some people add a spool valve on one of the outlets and keep the lever pulled back for a steady flow.
If you want to get a really in depth explanation IH published an excellent manual for the Liftall unit. You can get one from the good people here at YTMag.
http://www.ytmag.com/cgi-bin/store/mansrch.pl
Good luck with your H, Wm
