Re: Help with new Farmall H
Posted by Wayne Swenson on July 14, 2006 at 21:20:01 from (71.13.41.123):
In Reply to: Re: Help with new Farmall H posted by williamf on July 14, 2006 at 16:59:19:
williamf, I must disagree with your statement about the delayed lift on the rear outlet for the Lift-All. It only does that IF there is a delay valve installed at the fitting or cylinder. Check the pictures and it is plain to see. All 3 outlets work at the same time and same pressure; anything different is controlled outside of the pump.
As a former mechanics teacher, I wanted to be sure correct info is given.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
