Re: stuck valve Farmall MD
Posted by the Unforgiven on July 31, 2006 at 22:01:52 from (4.227.154.102):
In Reply to: stuck valve Farmall MD posted by lekwyo on July 31, 2006 at 20:43:19:
If it was a sticking valve causing the miss it should start to burn the valve after a few warm up cycles like that and then it would keep missing. Could you be down on compression in one hole and it has to warm up before it hits? Does it behave the same if you get it good and warm on gas, and does it hit on all four on gas?
