Re: Farmall A - left side brake and seals
Posted by banjo on August 12, 2006 at 09:19:35 from (65.67.203.150):
In Reply to: Farmall A - left side brake and seals posted by Tom Stein on August 12, 2006 at 08:24:19:
yes it will drop, but not completely. if you can't get the seal housing back on then you will probably have to remove the rear tranny cover so you can support the differential. but there may be other ways.
some folks use a slide hammer(dent puller) to pull the seals.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
