Re: Identify IHC plow in Implement Photos please
Posted by steelfronts on August 27, 2006 at 19:16:55 from (71.10.138.170):
In Reply to: Identify IHC plow in Implement Photos please posted by Gwiz on August 27, 2006 at 18:42:46:
Your plow is a #8 little genius tractor plow. It has been converted from a clutch lift to a hydraulic lift. The slatted part is the mold board, the part that hits the ground first is the point or share. Above the point and forward of the mold board is the shin. The part that slides against the furrow wall is the land side. They are all bolted on to the frog. I have some slat bottoms for parts.
