h not running right carb problems????
Posted by tim coltman on September 13, 2006 at 23:01:24 from (71.48.95.40):
hi trying to get my h running bought it about a month ago but havent hd time to mess with it untill now. i rewired it it was converted to 12 volt with the old harness. checked all plugs cap rotor all that is good like new almost. the carb had alittle rust in it so i went ahead and put in seals needle and seat. tried to start it and it fires rigt up with the choke on. revv it up and it sputters real bad and dies if your quick enough you can work the choke and throttle to keep it running after you rev it up but i cant keep it running for more than 15 20 seconds it always fires right back up and it will idle nice for about 10 seconds then die. i think its something with the carb but im not sure what. thanks for any help. tim
