Plowing with Fasthitch
Posted by Jeff P on November 07, 2006 at 05:12:57 from (207.28.116.1):
When plowing with a semi-mounted plow, do you have the fasthitch set to float or rigid? I have two different IH books one for IH plows that says the hitch should be rigid, and a book on the fasthitch that says you should set it up to float. Need your input. thanks
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
