Re: Farmall H Loader, Hydraulics Problem
Posted by Allan In NE on November 28, 2006 at 17:09:06 from (148.78.243.25):
In Reply to: Re: Farmall H Loader, Hydraulics Problem posted by Matt Compton on November 28, 2006 at 16:07:26:
Matt,
See where the bind is?
The H is a one-way system and you're trying to run it thru a two-way valve.
Just isn't gonna work, ol' Sport. You either need a one way (read: dump) valve or a loader that has two-way cylinders.
The way you have it plumbed now, when you want to "lower", that oil has no where to exit to because it is dead-heading (except for the bleed channel) inside that valve.
Allan
