340 U Hydraulic Oil Change Update
Posted by suumoe on December 03, 2006 at 13:51:20 from (76.4.91.50):
Replaced fluid and filter along with cleaning screen. Power steering was better but would still come and go at certain times. It may just be me,but it seems the steering works better at lower engine rpm. I would think it would be the other way around,the higher the pump rpm the greater the steering response. I am wondering since this is power assist instead of power steering maybe there is some sort of proportional valve in the power unit regulating flow during different steering situations. I have ordered a manual for it but hasn't arrived yet.What do you think tractor gurus? does this sound possible?
