IA,A,AV and B wheels
Posted by Roger Mills on December 11, 2006 at 08:18:58 from (204.13.130.86):
I saw a post or two a while back about the two mount lug styles vs plain rims for these and have some info. IA,A, plus B,BN with double front-- standard front hubs were stepped not flat and the rims had no lugs, just clamps-not adjustable--A plus B,BN double front were also available with "special order" adjustable fronts with flat hub and rims with small 'U' shaped lugs. IA does not have adjustable front wheels or flat hubs listed. AV had flat hubs with larger diameter rims that had wide flat "V" shaped mount lugs. Rims with these 'V' shaped lugs for the A and B are after market. B and BN could be "special ordered" with both rear inners from heavy cast rather than steel. An oddity was that there are half weights (about 70 lbs) that could be ordered for the left rear on an A to balance the "Big Bubba" sized drivers. Very few of these were ordered and I cannot find a part number for them.
