Pump noise?
Posted by Jiles on December 15, 2006 at 19:34:16 from (207.69.136.204):
I have a 364 I.H. and when I am lifting a heavy load sometimes the lift is strong enough that the front of the tractor will lift. Other times I can only lift a load about 3/4 of the lift arm travel and the pump makes a squealing sound and will not raise any further. This is while using a boom pole lift. The hydraulic oil is full and clean. It does this hot or cold. Any suggestions appreciated.
