Check oil levels
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by John on February 03, 2000 at 14:10:06 from (192.58.199.178):
How do I check the fluid levels in my '51 M? The Hydraulics I figured out. and the crankcase, too. But what about transmission and rearend? Are they seperate or the same?
While we're at it, I've put about three greasegun loads into the zerk fittings on the outboard ends of the axles -- where's it all going? How much more should I dump in there?
Thanks, John
Post A Followup
: Re: Check oil levels
