Re: 1940 H need the nitty-gritty
Posted by CNKS on January 09, 2007 at 17:53:33 from (204.249.178.32):
In Reply to: 1940 H need the nitty-gritty posted by SKK - Big Red Fan on January 09, 2007 at 17:29:12:
Go to www.caseih.com and look at the diagrams in the parts books, that won't answer all your questions but is a start. If your tractor was a gas only tractor, originally, I doubt if it had shutters, they were an option but were standard only on distillate/keosene models. I think the frame rails are cast not forged, so there won't be any casting numbers. Everything not absolutely necessary for the tractor to run was an option. Lights, starter, battery, hydraulics, light box, etc. It had a magneto as distributers were not yet available. The seat sounds original. The pistons were likely cast iron, available as standard and a couple of high altitute versions, there should be a suffix after the serial if high altitude were installed at the factory, although I am not positive that IH used suffixes that early. Guy Fay's books are all very helpful, but do not go into the type detail you want. Best to get an operators manual, pictures of nearly everything is in it and you need one anyway.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
