Re: 1940 H need the nitty-gritty
Posted by Wardner on January 09, 2007 at 18:11:59 from (206.148.21.16):
In Reply to: Re: 1940 H need the nitty-gritty posted by CNKS on January 09, 2007 at 17:53:33:
CNKS
Don't you mean "forged not cast". The part that attaches to bellhousing is welded to heavy, not standard, weight 4" channel and is still manufactured today.
I believe some of the early right hand channels of the '40 H still had the tractor serial stamped in as were all the '39's. It will be found at the front top flange of the channel.
I have a '40 H and memory tells me that the shutter crank mechanism penetrates the rear gas tank mount in a hole punched for that purpose.
