Re: Gasket Question
Posted by F-Dean on February 01, 2007 at 08:01:29 from (67.72.98.87):
In Reply to: Gasket Question posted by SuperA-Tx on January 31, 2007 at 14:59:23:
I always coat my gaskets in grease before I install them. Works well and you can take them off without any problems if you need to get inside again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
