Re: 500-C Crawler engine problem, Timing???
Posted by Janicholson on July 09, 2007 at 06:03:12 from (199.17.6.122):
In Reply to: 500-C Crawler engine problem, Timing??? posted by Doug from Pa on July 09, 2007 at 05:12:08:
If, when cranking, it seems to have compression (cranking sounds normal). If there is no white smoke. Then I would say it is the fuel system, and not mechanical. The lack of white smoke would indicate no injection of fuel.
It is pretty easy to check basic (runable) timing with the valve cover off and #1 injector out. The valve timing is going to be nearly identical to a gas engine (intake compression power exhaust) timed to piston travel. Good luck, JimN
