Re: 500-C Crawler engine problem, Timing???
Posted by Janicholson on July 09, 2007 at 16:56:53 from (66.173.50.173):
In Reply to: Re: 500-C Crawler engine problem, Timing??? posted by doug in pa on July 09, 2007 at 06:37:06:
You should not be able to turn it by "hand" unless the injectors are out of the head. If you can, it is possible to have the timing issue.
Fuel at the injectors is not the same as injected fuel. The amount of fuel is small, and the line being full is not a pump shot. I would have the injector pump vhecked if the timing I described seems OK. White smoke is always going to be there if it is injecting Diesel fuel. Even if timed wrong. A diesel compression tester may be needed. JimN
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
